Disable or Grey out Check box If Combo or Text Box Not Filled In
2010-10-14T18:47:39+00:00
I could get a combo box to disable text boxes using the code below, but how can I make this work if it isn't a text box and it is a check box?:
Private Sub Combo_Box_AfterUpdate()
Me.Text_Box.Enabled = (Me.Combo_Box.ListIndex >= 0)
End Sub
Microsoft 365 and Office | Access | For home | Windows
2010-10-14T21:56:54+00:00
A few things wrong here:
1.  You cannot compare something to Null.  Nothing equals Null, not even Null.  The IsNull function is used to determine if something is Null.
2.  In any case the Enabled property is either True or False, not Null.
So:
Private Sub Text_box_AfterUpdate()
    If IsNull(Me.text_box) Then
        Me.Text_box_2.Enabled = False
    Else
        Me.Text.box_2.Enabled = True
    End If
End Sub
or more succinctly:
     Me.Text.box_2.Enabled = Not IsNull(Me.text_box)
End Sub
If this is in a bound form and you want the Text.box_2 to be disabled when you move to an existing record where Text_box is Null, then also put the code in the form's Current event procedure.
Ken Sheridan, Stafford, England
56 additional answers
    2010-11-18T19:21:57+00:00
    okay so i tried this with the following code:
    Private Sub Persons_Present_Other_AfterUpdate()
    If Persons_Present_Other Then ' persons_present_other is ticked
         Me.Persons_Present_Other_Specify.Enabled = True
         Me.Persons_Present_Other_Specify.SetFocus
      Else
         Me.Persons_Present_Other_Specify.Enabled = False
      End If
    End Sub
    **Private Sub Check_Persons_Present_Other()**If Persons_Present_Other Then ' persons_present_other is ticked
      Else
      End If
    End Sub
    Then it gives me an error for invalid use of null for the bolded.
    2010-11-18T19:52:05+00:00
    I don't see anywhere in the code where Null would be a problem.
    But, I just noticed that the SetFocus line(s?) makes the code in the two procedures different so my argument about using a separate procedure to consolidate the code was a waste of time.  I guess you should skip that idea, delete the Check_Persons_Present_Other procedure and just add the line:
       Me.Persons_Present_Other_Specify.Enabled = Nz(Persons_Present_Other, False)
    to the form's Current event.  Leave the AfterUpdate event procedure as it is.
    2010-11-18T20:19:47+00:00
    okay, in order to make all similar fields perform like this, do I do this adding it to the form's current event? What about the private subs that don't have a setfocus code? What would I place for those in the form's current event?
    Thanks again.
    2010-11-18T20:46:59+00:00
    If all the AfterUpdate event does is enable/disable another control I don't see a significant reason to create a separate procedure for just one line of code though there would be nothing wrong with the idea if you want to do it.
    AFAICT, everything should be fine if you just add the one line to the Current event for each control.
