Disable or Grey out Check box If Combo or Text Box Not Filled In
2010-10-14T18:47:39+00:00
I could get a combo box to disable text boxes using the code below, but how can I make this work if it isn't a text box and it is a check box?:
Private Sub Combo_Box_AfterUpdate()
Me.Text_Box.Enabled = (Me.Combo_Box.ListIndex >= 0)
End Sub
Microsoft 365 and Office | Access | For home | Windows
2010-10-14T21:56:54+00:00
A few things wrong here:
1.  You cannot compare something to Null.  Nothing equals Null, not even Null.  The IsNull function is used to determine if something is Null.
2.  In any case the Enabled property is either True or False, not Null.
So:
Private Sub Text_box_AfterUpdate()
    If IsNull(Me.text_box) Then
        Me.Text_box_2.Enabled = False
    Else
        Me.Text.box_2.Enabled = True
    End If
End Sub
or more succinctly:
     Me.Text.box_2.Enabled = Not IsNull(Me.text_box)
End Sub
If this is in a bound form and you want the Text.box_2 to be disabled when you move to an existing record where Text_box is Null, then also put the code in the form's Current event procedure.
Ken Sheridan, Stafford, England
56 additional answers
    2010-11-18T01:31:01+00:00
    Okay so I got these codes to work, but I noticed an issue.  Say you have this code:
    Private Sub Event_Location_AfterUpdate()
    If Event_Location = "Other" Then
       Me.Event_Location_Other_Specify.Enabled = True
       Me.Event_Location_Other_Specify.SetFocus
    Else
       Me.Event_Location_Other_Specify.Enabled = False
       Me.Persons_Present_Agency_Staff.SetFocus
    End If
    End Sub
    If you selct the option "other", it allows you to proceed to the other box, but if you delete the word other and come back to this record it still allows you to type in that other box.  It won't grey it back out unless you reprocess the entire first box. I am having this same issue with check boxes that grey out other text fields. For example, if you check a box it ungreys a text field, but if you go to another record and come back to this record, the text field is greyed out again.
    2010-11-18T04:50:43+00:00
    That's because you only have the code run when you change the entry in Event_Location.  You need to have the same code in the form's Current event so it runs when you navigate to a record.
    The amount of code you have is about to the point where it would be a good idea to put it in it's own procedure:
    Private Sub Check_Event_Location()
    Else
    End If
    End Sub
    THen you can call it from the AfterUpdate event and from the Current event.  All it takes is simply using:
    You'll probably want to do the same kind of thing for other controls so the Current event would look something like:
       Check_This
       Check_That
    2010-11-18T18:26:51+00:00
    ok, just to make sure I got what you were saying.  Are you saying that along with my current code:
    Else
    End If
    End Sub
    I should create a new sub for each one of these and replicate the code like this:
    Else
    End If
    End Sub
    Then I place all the check_event_location, check_some_other field etc in the current form.  What is creating the check procedures for?
    2010-11-18T19:01:14+00:00
    When you need to use the same code in more than one place, you create a code maintenace problem because any change in one copy must be duplicated in the other place(s) and it's a pain to corrently make exactly the same changes multiple times.  Think of it as a kind of code normalization rule.
    If you can come up a fairly rigid pattern for a bunch of control that do essentially the same kind of thing, you may be able to use arguments to a single procedure that can be used for the whole bunch of controls, but that's starting to get moderately advanced.
