Disable or Grey out Check box If Combo or Text Box Not Filled In
2010-10-14T18:47:39+00:00
I could get a combo box to disable text boxes using the code below, but how can I make this work if it isn't a text box and it is a check box?:
Private Sub Combo_Box_AfterUpdate()
Me.Text_Box.Enabled = (Me.Combo_Box.ListIndex >= 0)
End Sub
Microsoft 365 and Office | Access | For home | Windows
2010-10-14T21:56:54+00:00
A few things wrong here:
1.  You cannot compare something to Null.  Nothing equals Null, not even Null.  The IsNull function is used to determine if something is Null.
2.  In any case the Enabled property is either True or False, not Null.
So:
Private Sub Text_box_AfterUpdate()
    If IsNull(Me.text_box) Then
        Me.Text_box_2.Enabled = False
    Else
        Me.Text.box_2.Enabled = True
    End If
End Sub
or more succinctly:
     Me.Text.box_2.Enabled = Not IsNull(Me.text_box)
End Sub
If this is in a bound form and you want the Text.box_2 to be disabled when you move to an existing record where Text_box is Null, then also put the code in the form's Current event procedure.
Ken Sheridan, Stafford, England
56 additional answers
    2010-12-06T23:52:50+00:00
    A word on check boxes.  They have three possible states True, False, Null.  To avoid problems that seem to be occurring here, begin by setting the default field value in the table to False.  You might also want to do the same for the check box on the form.  Once you have set the table's default value, create an update query to update all true/false fields to False where field=null.
    2010-12-07T00:59:20+00:00
    How can I make it so if something = "yes" that another text box can't be null otherwise a message pops up and won't allow you to continue until this is fixed?
  3. Deleted
    2015-05-27T19:37:32+00:00
    Hi turbon5.0,
    Hopefully you have found a solution by now, but if not something like this should work.
    If something.value="yes" then
    anothertextbox.value<>""
    if anothertextbox.value=""then
    msgbox ("Error Message", "Title")
    End if
    End if
