Disable or Grey out Check box If Combo or Text Box Not Filled In
2010-10-14T18:47:39+00:00
I could get a combo box to disable text boxes using the code below, but how can I make this work if it isn't a text box and it is a check box?:
Private Sub Combo_Box_AfterUpdate()
Me.Text_Box.Enabled = (Me.Combo_Box.ListIndex >= 0)
End Sub
Microsoft 365 and Office | Access | For home | Windows
2010-10-14T21:56:54+00:00
A few things wrong here:
1.  You cannot compare something to Null.  Nothing equals Null, not even Null.  The IsNull function is used to determine if something is Null.
2.  In any case the Enabled property is either True or False, not Null.
So:
Private Sub Text_box_AfterUpdate()
    If IsNull(Me.text_box) Then
        Me.Text_box_2.Enabled = False
    Else
        Me.Text.box_2.Enabled = True
    End If
End Sub
or more succinctly:
     Me.Text.box_2.Enabled = Not IsNull(Me.text_box)
End Sub
If this is in a bound form and you want the Text.box_2 to be disabled when you move to an existing record where Text_box is Null, then also put the code in the form's Current event procedure.
Ken Sheridan, Stafford, England
56 additional answers
  1. Deleted
    2010-12-06T18:31:05+00:00
    Okay, I have another problem. Say I have field "A" enabled. When field A is enabled, I don't want the user to be able to move on without either filling this field in or unchecking the box that enabled field "A". How can I do this? Thanks
    2010-12-06T23:02:59+00:00
    Here are the two codes that I currently have.  I need it so Follow_Up_Date can't be left blank if it is enabled.  So the user can't move on without having this field disabled or filled in.
    Private Sub Additional_Follow_Up_Required_AfterUpdate()
    If Additional_Follow_Up_Required Then
        Me.Follow_Up_Date.Enabled = True
        Follow_Up_Date.SetFocus
      Else
        Me.Follow_Up_Date.Enabled = False
        Follow_Up_Date = Null
      End If
    End Sub
    Private Sub Follow_Up_Date_AfterUpdate()
    If Not IsNull(Follow_Up_Date) Then
        Me.Follow_Up_Within_5_Business_Days.Enabled = True
      Else
        Me.Follow_Up_Within_5_Business_Days.Enabled = False
        Follow_Up_Within_5_Business_Days = Null
      End If
    End Sub
    2010-12-06T23:38:27+00:00
    Let me add to this long winded discussion...  In all these efforts, you have code all over the place doing different things.  Here is the simplified path:
    Start by creating a single Sub procedure to handle all of controls on the form.
    Private Sub ManageControls()
      Me.MyControl1.Enabled = [Validation]  (i.e. Not IsNull(Me.MyControl0) or Not IsNull(Me.MyField0), etc.)
      Me.MyControl2.Enabled = [Validation]  (i.e. Me.MyControl1.Enabled)
      And so on...
    End Sub
    for each of your controls that affects subsequent controls, add the event procedure AfterUpdate and insert the call to the above Sub Procedure.
    Private Sub MyControl1_AfterUpdate()
       ManageControls
    End Sub
