Disable or Grey out Check box If Combo or Text Box Not Filled In
2010-10-14T18:47:39+00:00
I could get a combo box to disable text boxes using the code below, but how can I make this work if it isn't a text box and it is a check box?:
Private Sub Combo_Box_AfterUpdate()
Me.Text_Box.Enabled = (Me.Combo_Box.ListIndex >= 0)
End Sub
Microsoft 365 and Office | Access | For home | Windows
2010-10-14T21:56:54+00:00
A few things wrong here:
1.  You cannot compare something to Null.  Nothing equals Null, not even Null.  The IsNull function is used to determine if something is Null.
2.  In any case the Enabled property is either True or False, not Null.
So:
Private Sub Text_box_AfterUpdate()
    If IsNull(Me.text_box) Then
        Me.Text_box_2.Enabled = False
    Else
        Me.Text.box_2.Enabled = True
    End If
End Sub
or more succinctly:
     Me.Text.box_2.Enabled = Not IsNull(Me.text_box)
End Sub
If this is in a bound form and you want the Text.box_2 to be disabled when you move to an existing record where Text_box is Null, then also put the code in the form's Current event procedure.
Ken Sheridan, Stafford, England
56 additional answers
    2010-11-23T16:24:13+00:00
    I still have no idea how null is intruding into this situation.
    Nz(X, False) will return True if X is True.  It will return False if X is False or Null.  Remember that No, False and 0 all mean the same thing.
    I think the confusion is because you are looking at the Format property, seeing the named format Yes/No and confusing it with the data type.  Just because the Yes/No format displays 0 as No instead of False has nothing to do with anything beyond what you see in a text box, the value is still 0.
    When you get into creating your own custom formats, you will see that you can display a Yes/No (boolean) data type value (-1/0 or True/False) just about any way you want.  For example, you could use the format specification
       "Oops";"Success";"Failure"
    to get a text box to display Success or Failure instead of Yes or No.
    2010-11-25T00:27:06+00:00
    Thanks,  I understand the Nz(X, False) will return True if X is True.  It will return False if X is False or Null.  Remember that No, False and 0 all mean the same thing, but I don't see where it is saying that only if true to enable the specified fields.  The second procedure that you gave me clearly states to only enable when true, but I don't see where this one does this.  It works, but I just want to try to understand the statements.
    2010-11-25T01:38:30+00:00
    If we're talking about the same code:
       If Nz(Who_Was_Notified_Police, False) Then
           Me.Who_Was_Notified_Police_Name.Enabled = True
    The Enable = True lines will run when Nz(Who_Was_Notified_Police, False) is True and that will happen only when Who_Was_Notified_Police is True
    Maybe it would be clearer using a redundant comparison:
       If Nz(Who_Was_Notified_Police, False)=True Then
    The =True is unnecessary because, when Nz(Who_Was_Notified_Police, False) is True, then Nz(Who_Was_Notified_Police, False)=True will still be True
    2010-12-02T00:47:55+00:00
    I understand that it will run when true, it's just that I don't see it in the code that it states only when true that it will run.  Unlike the second option you gave it clearly states when = true.  Is this code just one of those that you have to know it only works when true and it's something that can't be seen?  To me it looks like it is stating if the field is null to make it say false.
