Finding the character where two strings do not match
2010-06-11T16:18:02+00:00
I have 2 cells B2 and C2 with strings.
I can tell whether they match or not easily enough.  But I am not sure how to identify the character where the two strings diverge.  Can it be done with a formula (ideas?) or do I need to create a new one (eh?)?
Thanks all. :)
2010-06-12T14:02:24+00:00
Nice formula Bernd; however, I would suggest this modification to it so that it can be copied down into blank rows (in anticipation of future entries)...
=IF(AND(B2="",C2=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2)))))
I would note for the OP that this formula is entered normally (that is, it is NOT an array-entered formula). And I would also note that the formula is is case-sensitive; the case-insensitive version of it would be this...
=IF(AND(B14="",C14=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&UPPER(B14),ROW(INDIRECT("1:"&1+LEN(B14))))," "&UPPER(C14))),ROW(INDIRECT("1:"&1+LEN(B14)))))
2010-06-12T09:25:06+00:00
Thanks all. :)
I suggest to use
=LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2))))
Regards,
Bernd
PS: [Edited on 12-June 11:57 GMT] If VBA is an option you can also use
Function NonMatchPos(s1 As String, s2 As String) As Long
Dim i As Long
i = 1
Do While i <= Len(s1) And i <= Len(s2)
    If Mid(s1, i, 1) <> Mid(s2, i, 1) Then Exit Do
    i = i + 1
Loop
NonMatchPos = i
End Function
www.sulprobil.com
48 additional answers
    2010-06-12T07:00:48+00:00
    I get a #NAME? error with your F3 formula because I am using XL2003... IFERROR is an XL2007 (and XL2010 I guess) function, so that formula appears to be limited to that version of Excel.
    2010-06-12T09:51:31+00:00
    ------------------------Excellent-----------------------
    If this post answers your question, please mark it as the Answer.
    Mike H
  3. Micky Avidan *** מיקי אבידן 16,531 Reputation points MVP Volunteer Moderator
    2010-06-12T16:15:27+00:00
    Hi, Rick,
    Unfortunatelly your Case-sensitive formula fails at:
    A1                   B1
    a assdfg
    Shalom and Shavua Tov,
    Micky (Microsoft® MVP - Excel)
