Finding the character where two strings do not match
2010-06-11T16:18:02+00:00
I have 2 cells B2 and C2 with strings.
I can tell whether they match or not easily enough.  But I am not sure how to identify the character where the two strings diverge.  Can it be done with a formula (ideas?) or do I need to create a new one (eh?)?
Thanks all. :)
2010-06-12T14:02:24+00:00
Nice formula Bernd; however, I would suggest this modification to it so that it can be copied down into blank rows (in anticipation of future entries)...
=IF(AND(B2="",C2=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2)))))
I would note for the OP that this formula is entered normally (that is, it is NOT an array-entered formula). And I would also note that the formula is is case-sensitive; the case-insensitive version of it would be this...
=IF(AND(B14="",C14=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&UPPER(B14),ROW(INDIRECT("1:"&1+LEN(B14))))," "&UPPER(C14))),ROW(INDIRECT("1:"&1+LEN(B14)))))
2010-06-12T09:25:06+00:00
Thanks all. :)
I suggest to use
=LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2))))
Regards,
Bernd
PS: [Edited on 12-June 11:57 GMT] If VBA is an option you can also use
Function NonMatchPos(s1 As String, s2 As String) As Long
Dim i As Long
i = 1
Do While i <= Len(s1) And i <= Len(s2)
    If Mid(s1, i, 1) <> Mid(s2, i, 1) Then Exit Do
    i = i + 1
Loop
NonMatchPos = i
End Function
www.sulprobil.com
48 additional answers
    2010-06-11T21:36:30+00:00
    =LOOKUP(2,1/(1=FIND(LEFT(" "&A2&REPT("|",1+LEN(A1)),ROW(INDIRECT("1:"&2+LEN(A2)))),
    " "&A1&REPT("#",1+LEN(A2)))),ROW(INDIRECT("1:"&2+LEN(A2))))
    "|" and "#" should not appear in your input.
    Regards,
    Bernd
    PS: I do not like worksheet functions of this length :-)
    www.sulprobil.com
    You mean FORMULAS, right? <g>
    Programmers always want to reinvent the wheel.
    We're seeing you a lot in these forums, Bernd. Why didn't you post this much in the ng's?
    On a side note: while I disagree with your reasoning for not wanting to use Morefunc at all (open source), I am starting to come around to idea of maybe not using it in Excel 2007 as it seems there are some "bugs" when using it in Excel 2007.
    Biff
    Microsoft Excel MVP
    Hello Biff,
    Right, I mean formulas - but I deleted that because I like it far more than the other formulas I saw so far. (Btw: Why do you "sit" 54 minutes on my post? :-)
    A side note: You think the number of my posts here is higher than in NG's previously? Well, let us see. With regards to Morefunc: It is a pity that we cannot get the source code. But since we obviously are not able to get it, I beg to differ with you. I think you would agree that it's fun to disagree sometimes (at least: with me :-).
    Regards,
    Bernd
    www.sulprobil.com
    2010-06-11T21:44:24+00:00
    Sorry, I have no idea what that means?
    Biff Microsoft Excel MVP
    2010-06-11T21:53:48+00:00
    OT: I thought I had changed my post quite soon and I was surprised that you were able to see and to answer to the original one - but maybe I am mistaken ...
    www.sulprobil.com
