Finding the character where two strings do not match
2010-06-11T16:18:02+00:00
I have 2 cells B2 and C2 with strings.
I can tell whether they match or not easily enough.  But I am not sure how to identify the character where the two strings diverge.  Can it be done with a formula (ideas?) or do I need to create a new one (eh?)?
Thanks all. :)
2010-06-12T14:02:24+00:00
Nice formula Bernd; however, I would suggest this modification to it so that it can be copied down into blank rows (in anticipation of future entries)...
=IF(AND(B2="",C2=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2)))))
I would note for the OP that this formula is entered normally (that is, it is NOT an array-entered formula). And I would also note that the formula is is case-sensitive; the case-insensitive version of it would be this...
=IF(AND(B14="",C14=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&UPPER(B14),ROW(INDIRECT("1:"&1+LEN(B14))))," "&UPPER(C14))),ROW(INDIRECT("1:"&1+LEN(B14)))))
2010-06-12T09:25:06+00:00
Thanks all. :)
I suggest to use
=LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2))))
Regards,
Bernd
PS: [Edited on 12-June 11:57 GMT] If VBA is an option you can also use
Function NonMatchPos(s1 As String, s2 As String) As Long
Dim i As Long
i = 1
Do While i <= Len(s1) And i <= Len(s2)
    If Mid(s1, i, 1) <> Mid(s2, i, 1) Then Exit Do
    i = i + 1
Loop
NonMatchPos = i
End Function
www.sulprobil.com
48 additional answers
    2010-06-11T20:25:14+00:00
    >Thanks all. :)
    Here's a different approach using a VBA Macro.
    It will color the characters in the strings in columns B & C starting
    at the place where they don't match.
    To enter this Macro (Sub), <alt-F11> opens the Visual Basic Editor.
    Ensure your project is highlighted in the Project Explorer window.
    Then, from the top menu, select Insert/Module and
    paste the code below into the window that opens.
    To use this Macro (Sub), <alt-F8> opens the macro dialog box. Select
    the macro by name, and <RUN>.
    It will automatically look at all the entries in column B from B2 to
    the lowest row, and compare that with the corresponding entries in
    Column C.
    One limitation is that it will only alter actual strings. It will not
    work on strings that are the result of formulas.
    Option Explicit
    Sub StringDiff()
    'Higlights string starting where they differ
    Dim rg As Range, c As Range
    Dim i As Long
    Dim s1 As String, s2 As String
    'This is just one of many ways to set up the
    ' range to check
    Set rg = Range("B2", Cells(Rows.Count, "B").End(xlUp))
    'Anything in the range?
    If rg(1, 1).Address = "$B$1" Then
    MsgBox ("No data in column B")
    Exit Sub
    End If
    For Each c In rg
    s1 = c.Text: s2 = c(1, 2).Text
    'to change any formula produced strings to
    'actual strings.
    'comment next line out if that is not desired
    c.Value = s1: c(1, 2).Value = s2
    c.Font.Color = vbBlack
    c(1, 2).Font.Color = vbBlack
    For i = 1 To IIf(Len(s1) > Len(s2), Len(s1), Len(s2))
    c.Characters(i, 255).Font.Color = vbRed
    c(1, 2).Characters(i, 255).Font.Color = vbRed
    End If
    Next i
    Next c
    End Sub
    2010-06-11T20:27:11+00:00
    I've noticed that I'm getting unexpected results.
    The formula is returning some strange results:
    Text 1             Text 2            Formula Result
    aaaaaa           aaaaab           6  (This is correct)
    blah                blax               4  (this is also correct)
    apple              bpple              6
    aaaaaaaaab    aaaaaaaaac    10
    aaaaaa           aabbab           6
    Now:
    If copy the formula to the next line, I get:
    aaaaaa           aaaaab           2
    Once I go into the 2nd formula's cell and do a ctrl-shift-enter, the result is 5.
    Can array-entered functions be copy/pasteed?
    2010-06-11T20:54:47+00:00
    =LOOKUP(2,1/(1=FIND(LEFT(" "&A2&REPT("|",1+LEN(A1)),ROW(INDIRECT("1:"&2+LEN(A2)))),
    " "&A1&REPT("#",1+LEN(A2)))),ROW(INDIRECT("1:"&2+LEN(A2))))
    "|" and "#" should not appear in your input.
    Regards,
    Bernd
    PS: I do not like worksheet functions of this length :-)
    www.sulprobil.com
    You mean FORMULAS, right? <g>
    Programmers always want to reinvent the wheel.
    We're seeing you a lot in these forums, Bernd. Why didn't you post this much in the ng's?
    On a side note: while I disagree with your reasoning for not wanting to use Morefunc at all (open source), I am starting to come around to the idea of maybe not using it in Excel 2007 as it seems there are some "bugs" when using it in Excel 2007.
    Biff
    Microsoft Excel MVP
