Finding the character where two strings do not match
2010-06-11T16:18:02+00:00
I have 2 cells B2 and C2 with strings.
I can tell whether they match or not easily enough.  But I am not sure how to identify the character where the two strings diverge.  Can it be done with a formula (ideas?) or do I need to create a new one (eh?)?
Thanks all. :)
2010-06-12T14:02:24+00:00
Nice formula Bernd; however, I would suggest this modification to it so that it can be copied down into blank rows (in anticipation of future entries)...
=IF(AND(B2="",C2=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2)))))
I would note for the OP that this formula is entered normally (that is, it is NOT an array-entered formula). And I would also note that the formula is is case-sensitive; the case-insensitive version of it would be this...
=IF(AND(B14="",C14=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&UPPER(B14),ROW(INDIRECT("1:"&1+LEN(B14))))," "&UPPER(C14))),ROW(INDIRECT("1:"&1+LEN(B14)))))
2010-06-12T09:25:06+00:00
Thanks all. :)
I suggest to use
=LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2))))
Regards,
Bernd
PS: [Edited on 12-June 11:57 GMT] If VBA is an option you can also use
Function NonMatchPos(s1 As String, s2 As String) As Long
Dim i As Long
i = 1
Do While i <= Len(s1) And i <= Len(s2)
    If Mid(s1, i, 1) <> Mid(s2, i, 1) Then Exit Do
    i = i + 1
Loop
NonMatchPos = i
End Function
www.sulprobil.com
48 additional answers
    2010-06-11T18:14:42+00:00
    How about the following array:
    =MATCH(FALSE,(MID(A1,ROW(1:9),1)=MID(B1,ROW(1:9),1)),0)
    Increase 1:9 to as large a value as you want to handle the longest text in the cells
    If this answer solves your problem, please check Mark as Answered. If this answer helps, please click the Vote as Helpful button. Cheers, Shane Devenshire
    2010-06-11T18:30:52+00:00
    It appears that your formula will fail if the two text strings are identical.
    2010-06-11T18:44:57+00:00
    Okay, forget the formula I posted... it will not always work correctly, nor is the first one case-sensitive. Instead, give this array-entered** formula a try (it is case-insensitive)...
    =MAX(IF(MID(B2,ROW(INDIRECT("1:"&MAX(LEN(B2),LEN(C2)))),1)<>MID(C2,ROW(INDIRECT("1:"&MAX(LEN(B2),LEN(C2)))),1),0,ROW(INDIRECT("1:"&MAX(LEN(B2),LEN(C2)))))+1)
    ** Commit either of these formulas by pressing Ctrl+Shift+Enter (NOT just enter by itself)
