Finding the character where two strings do not match
2010-06-11T16:18:02+00:00
I have 2 cells B2 and C2 with strings.
I can tell whether they match or not easily enough.  But I am not sure how to identify the character where the two strings diverge.  Can it be done with a formula (ideas?) or do I need to create a new one (eh?)?
Thanks all. :)
2010-06-12T14:02:24+00:00
Nice formula Bernd; however, I would suggest this modification to it so that it can be copied down into blank rows (in anticipation of future entries)...
=IF(AND(B2="",C2=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2)))))
I would note for the OP that this formula is entered normally (that is, it is NOT an array-entered formula). And I would also note that the formula is is case-sensitive; the case-insensitive version of it would be this...
=IF(AND(B14="",C14=""),"",LOOKUP(2,1/(1=FIND(LEFT(" "&UPPER(B14),ROW(INDIRECT("1:"&1+LEN(B14))))," "&UPPER(C14))),ROW(INDIRECT("1:"&1+LEN(B14)))))
2010-06-12T09:25:06+00:00
Thanks all. :)
I suggest to use
=LOOKUP(2,1/(1=FIND(LEFT(" "&B2,ROW(INDIRECT("1:"&1+LEN(B2))))," "&C2)),ROW(INDIRECT("1:"&1+LEN(B2))))
Regards,
Bernd
PS: [Edited on 12-June 11:57 GMT] If VBA is an option you can also use
Function NonMatchPos(s1 As String, s2 As String) As Long
Dim i As Long
i = 1
Do While i <= Len(s1) And i <= Len(s2)
    If Mid(s1, i, 1) <> Mid(s2, i, 1) Then Exit Do
    i = i + 1
Loop
NonMatchPos = i
End Function
www.sulprobil.com
48 additional answers
    2010-06-14T14:53:23+00:00
    I see you marked my modification of Bernd Pl's as the "Answer". I just wanted to advise you that you can mark more than one response to your question as an "Answer". Because my response was built on the formula that Bernd posted, I think it would only be fair if you would mark his message as an "Answer" too... plus, if your final solution made use of any other postings, you might want to consider including them as "Answers" as well.
    2010-06-14T17:36:39+00:00
    Bernd Pl schrieb am 12.06.2010 11:25 Uhr:
    [... Code ...]
    How will you distinguish these two results?
    "abc" / "abc"  => 4
    "abc" / "abcd" => 4
    And the following result is at least strange.
    "" / "" => 1
    The following code returns 0 if both strings are equal.
    Peter
    Function NotMatch(ByVal s1 As String, ByVal s2 As String) As Long
       For NotMatch = 1 To WorksheetFunction.Min(Len(s1), Len(s2))
          If Mid(s1, NotMatch, 1) <> Mid(s2, NotMatch, 1) Then Exit For
       Next
       If NotMatch > Len(s1) And Len(s1) = Len(s2) Then NotMatch = 0
    End Function
    2010-06-14T21:22:59+00:00
    For those that enjoy arrays I have devised a shorter array than my previously suggested one, and it does not require 2007 and it handle leading spaces in the second argument, however, it does not handle errors elegenty, it propogates them.  F2 below:
    All of these formulas handle all special characters in the ASCII code set.
    Summary of analysis:
    F1: =IFERROR(MATCH(0,--EXACT(MID(A1,ROW($1:$10),1),MID(B1,ROW($1:$10),1)),),LEN(A1)+1)
    F2:  =MATCH(1,FIND(LEFT(" "&A1,ROW(INDIRECT("1:"&1+LEN(A1))))," "&B1),1)
    F3:  =LOOKUP(2,1/(1=FIND(LEFT(" "&A1,ROW(INDIRECT("1:"&1+LEN(A1))))," "&B1)),ROW(INDIRECT("1:"&1+LEN(A1))))
    F4:  =SUMPRODUCT(--ISNUMBER(FIND(LEFT(" "&A1,ROW(INDIRECT("1:"&1+LEN(A1))))," "&B1)))
    Issue F1 F2 F3 F4
    The only position inwhich spaces cause problems is the leading position of the 2nd argument. | Array Entered | Yes | Yes | No | No |
    | Require 2007 or later | Yes | No | No | No |
    | Error propogation problem? | Yes | Yes | Yes | No |
    | Handle leading space in 2nd argument | Yes | Yes | Yes | No |
    If this answer solves your problem, please check Mark as Answered. If this answer helps, please click the Vote as Helpful button. Cheers, Shane Devenshire
