Opening old Power Point files
2010-02-04T02:28:59+00:00
I have a large number of Power Point files that were created in 1995, 1996, 1997, and later using then current versions of Power Point (3.0 and earlier versions I think they were ... and since these were federal governement computers the operating system was probably whatever was before Windows 95).  I upgraded to Windows Vista 64 anad a new computer in August 2009, with Office 2007 and recently needed to open a Power Point presentation from 1997 and use it the historical data in a new presentation.  My computer wouldn't open the file and said that my current Power Point doesn't support earlier versions.  I then tried to open the 1997 file one of my other computers that has Windows XP and Office 2003.  The file wouldn't open on that computer either giving a similar message.  I also have an antique computer with Windows 98 that isn't very reliable, some of these old Power Point files can open on that computer with a little animation of pages flying through the air saying it is updating from an older version of Power Point.  I have hundreds of old Power Point files and some of them still have relevant historical information that I need to use occasionally without having to remember the details of what I put on them then.  How can I open these old Power Point files on my new computer?
2010-02-04T05:27:31+00:00
Hi
I'm afraid 2007 won't open really old files (saved in '97 format or earlier I believe) but 2003 might. If 2003 won't, you need to find a computer running an older version and try again... There may be some 'issues' (particularly with animations from pre XP/2002) but at least you'll have a starting point. Once you have found a computer that will open the files this should help:
Batch re-save presentations; update older presentations to newer PowerPoint version
http://www.pptfaq.com/FAQ00740.htm
I advise you to update all the files when you find the equipment to do so :-)
Lucy
Lucy Thomson
PowerPoint MVP
an easier tomorrow
42 additional answers
    2013-03-05T22:11:24+00:00
    Probably means it really is corrupt or maybe a very very old version (pre 95)
    I'm trying to open files from the course schedule on this page.  http://www.cs.berkeley.edu/~pattrsn/252S98/index.html
    2013-03-05T23:17:08+00:00
    I tried a couple of files from there (in so called 98 format) They opened both in PPT 2010 and (although there was no need) in Zamzar.
  3. Steve Rindsberg 99,176 Reputation points MVP Volunteer Moderator
    2013-03-06T16:50:20+00:00
    Other than zamzar, I don't know that there's anything like this.
    I doubt skydrive could do it because it's probably based on the same code as current versions of PowerPoint itself.
    I've toyed with the idea of setting up a service like this but there doesn't seem to be much interest in it.
  4. Deleted
