page numbers not showing on slides
2010-02-04T18:16:13+00:00
the page numbers i try to place using footer and slide numbers boxes will not show.  background appears to be blocking it.
2010-02-04T22:19:23+00:00
Hi
Did you use Insert -> Header & Footer? Check to see if the page number placeholder is truned on on the Master - View -> Slide Master -> Slide Master tab -> Master Layout -> check 'Slide Number' is ticked. If it is and you still can't see it it may be behind another element on the slide master - select the 'mother' master (the big one at the top) then Home -> Select drop down -> Selection Pane -> select 'Slide Number Placeholder' -> click the re-order up button (at the bottom of the taskpane) until the slide number placeholder is at the top.
If none of that works, let us know exactly what you have tried and exactly what is happening. Also, if the file was created in a previous version or has been edited in a previous version.
Lucy
Lucy Thomson
PowerPoint MVP
an easier tomorrow
42 additional answers
  1. Steve Rindsberg 99,176 Reputation points MVP Volunteer Moderator
    2016-06-05T04:16:55+00:00
    Do try the suggestions in my other post first, if you haven't already.
    You'll find that here:
    http://answers.microsoft.com/en-us/office/forum/office_2007-powerpoint/page-numbers-showing-same-number/5ee7cb4d-6682-4c95-a97f-3980a13a6a62
    If you still need to send a link to a file, you can pretty much delete everything but the slide numbers from the slides to be sure that you don't turn loose of anything confidential.
    2016-08-09T18:50:02+00:00
    OK - this is retarded, come on Microsoft, people don't have time to be dorking around on the internet searching for several solutions to fix this that don't fix it - why don't you fix it? You've had plenty of "upgrades" to do this in. THIS IS UNACCEPTABLE. FIX IT.
    I honestly can't believe how convoluted this is - I am not a beginner with PPT, I've been working with it for years preparing presentations for people who are supposedly "proficient" in word, ppt and excel - at least that's what their resumes say. The only reason I work in PPT is to support these people so the don't make ugly presentations - or to make it do things they just can't comprehend.
    I also work in other pro software - Adobe namely, from InDesign to Photoshop, Illustrator, Acrobat, Aftereffects, Premier.... you would be doing yourself a favour to take a few ques from them - add a page reference onto a master page - boom, done.
    After all these years - I can't believe how little you've done to improve the software - really - what is the problem? Do you think we don't notice that for all intensive purposes you largely repackage your software from the previous version? Ever heard of Quark - that's what they did and now where are they? Nowhere.
    Get your act together - please, because I've wasted a lot of time looking up everyone's solutions that don't work and in writing this response - un-billable time.
    Are you here to help us or to waste our time and money?
    I don't appreciate buying a product that does not live up to the advertising broadcasted by the company that made it. FIX IT.
  3. Steve Rindsberg 99,176 Reputation points MVP Volunteer Moderator
    2016-08-10T16:31:03+00:00
    With you 100% on this one.  But understand that here, on this forum, you're not talking to the PPT developers, program managers or anyone else who can actually DO anything about the problem.  Here, you're complaining to other users who offer volunteer support, for the most part.
    If you want the developers to hear your suggestion, go to powerpoint.uservoice.com
    Suggestions posted there DO get in front of the devs/program managers.
    2016-08-10T16:37:39+00:00
    Tip appreciated - thank you.
