OneNote Linked Notes Window is docking on top of screen not the side
2010-07-15T14:25:16+00:00
Somehow,.... I don't know how, my "linked Notes" window has started to dock on top of my screen.  It cannot be moved, sized, or otherwise adjusted.  I've checked the "dock new sidenotes to the side of the desktop" in the options.  I've seen a few other people mention this problem of locating the docking window, but so far no answers.
Thanks for the help
OneNote 2010
Windows 7
2010-09-03T23:50:01+00:00
I had the same problem. Dragging the top bar to the right side of the screen while it's docked does the trick. It doesn't look like you are dragging it when you are doing it, but when you release it at the side of the screen, OneNote readjusts to a right-side docked position.
600+ people found this answer helpful.
45 additional answers
    2010-08-26T20:21:40+00:00
    Hi!
    Did you ever get this problem solved?  Mine used to dock vertically to the desktop, but now it docks horizontally top and bottom.   I don't know how it happened, but I would like to know if you know how to switch back to vertical docking.
    Please let me know if you can help.
    Thanks!
    2010-12-07T02:32:36+00:00
    this is totally the right answer, thanks! I had the same problem.  the no visual cues is the key. You don't know its happening until it clicks into proper position, then it works.
    2010-12-07T23:24:47+00:00
    Hey Maochen!
    I was just checking back in... and realized that you used my first name... vs. the display name of shadow49!  ..... wow!  and I thought google was spooky!
    2010-12-13T18:41:59+00:00
    Had the same issue.  Would not matter if docking to desktop via the View (as Ruchi suggests), by Linked Notes, or by toolbar; also stuck on top of screen.  SaraBlax's answer below worked - finally something worked!  I have dual screens, but dragging it over to the right column of my second screen reset the docking.  As she pointed out, it does not appear as anything is happening; but it is!  So glad to have this repaired.  Can now begin taking linked notes again (awesome feature for OneNote, by the way)
