OneNote Linked Notes Window is docking on top of screen not the side
2010-07-15T14:25:16+00:00
Somehow,.... I don't know how, my "linked Notes" window has started to dock on top of my screen.  It cannot be moved, sized, or otherwise adjusted.  I've checked the "dock new sidenotes to the side of the desktop" in the options.  I've seen a few other people mention this problem of locating the docking window, but so far no answers.
Thanks for the help
OneNote 2010
Windows 7
2010-09-03T23:50:01+00:00
I had the same problem. Dragging the top bar to the right side of the screen while it's docked does the trick. It doesn't look like you are dragging it when you are doing it, but when you release it at the side of the screen, OneNote readjusts to a right-side docked position.
600+ people found this answer helpful.
45 additional answers
    2010-07-16T12:35:29+00:00
    For this issue, it's totally a window issue, instead of the cache.
    2010-07-16T12:44:28+00:00
    If the above step does not resolve the issue try to open OneNote in
    safeboot mode to do this,
    Click start->Run(Windows key + R key) and type OneNote /safeboot and
    select clear cache and click ok.
    Why do you suggest to clear the cache as a instrument for every this
    that??
    Clearing the cache may be necessary for some problems. But for sure
    not for things with the GUI!
    Rainald
    2010-07-16T12:46:45+00:00
    Exactly!
    Rainald
    2010-07-17T11:53:34+00:00
    I had a similar view which was fixed by doing a complete safeboot of onenote. This included clear cache.
    It's worth a try. It does not remove any file or data from within onenote.
    But as you mentioned you could also check the windows settings.
