OneNote Linked Notes Window is docking on top of screen not the side
2010-07-15T14:25:16+00:00
Somehow,.... I don't know how, my "linked Notes" window has started to dock on top of my screen.  It cannot be moved, sized, or otherwise adjusted.  I've checked the "dock new sidenotes to the side of the desktop" in the options.  I've seen a few other people mention this problem of locating the docking window, but so far no answers.
Thanks for the help
OneNote 2010
Windows 7
2010-09-03T23:50:01+00:00
I had the same problem. Dragging the top bar to the right side of the screen while it's docked does the trick. It doesn't look like you are dragging it when you are doing it, but when you release it at the side of the screen, OneNote readjusts to a right-side docked position.
600+ people found this answer helpful.
45 additional answers
    2014-02-20T20:40:34+00:00
    Ah my split screen has been stuck the wrong way for ages. THANK YOU!
