A family of Microsoft word processing software products for creating web, email, and print documents.
For the error message "There was a problem sending the command to the program", use Windows Explorer to access the C:\Program Files\Microsoft Office\Office15 folder and right click on WINWORD.EXE then on Properties, go to the Compatibility tab and uncheck all the boxes.
It has also been reported that the problem can be overcome by editing the registry at
HKEY_CLASSES_ROOT\Word.Document.12\shell\Open and deleting the ddeexec key.
The ddeexec can also be deleted from
HKEY_CLASSES_ROOT\Word.DocumentMacroEnabled.12\shell\Open.
That fix is described at ...
http://www.dilloway.co.uk/there-was-a-problem-sending-the-command.html
