receiving many spam emails from sender renew@
2024-07-16T17:11:22+00:00
Every day I receive 20-30 emails where the sender from address starts with renew@ (see image below) Outlook is placing these messages in the Junk email folder. But, every day I have to scan the Junk mail folder looking for appropriate messages that should have shown up in my Inbox.
I would like to create a Rule that automatically deletes any message in the Junk email folder who's sender name begins with "renew@"
I have actually created a rule but I cannot figure out how to run it against the Junk email folder.
    2024-09-06T13:37:05+00:00
    Sure, that would work, although they are not in my inbox. They are in my junk email folder. This is just as annoying and creating rules for this folder isn't possible. Thanks for your reply! Incidentally, there are quite a few users having the same problem from renew@ and preview@. I would think Microsoft would notice this and make a correction. Making a feedback request is ineffective.
    When you "Run Rules Now" it will allow you to select the folder you want it to run against, i.e the Junk folder.
    2024-09-06T13:57:40+00:00
    Exact! And if you create a macro and use a button to trigger the macro, it becomes easy.
    Video
    2024-09-06T14:07:50+00:00
    Thank you, Frank! I am using the low-end online version of outlook. It does not have your features and rules are only permitted for the inbox folder. You are using Microsoft 360, as well as YvesLarin !
    2024-09-06T14:17:54+00:00
    Video
    Ahh, works like a charm!
    2024-09-06T14:27:22+00:00
    My outlook website doesn't show these options...
