Classic Outlook - Until when will it be supported & available for use?
2024-08-22T13:32:08+00:00
Can users with Classic outlook continue using it in 2025?
    2025-02-11T04:55:43+00:00
    You are actually suggesting the typical Outlook user go in to the registry and change a setting?
    Otherwise, thanks for the details. Oddly windows 11 removed the icon I set up yesterday for classic outlook after I rebooted.
    2025-02-11T05:02:44+00:00
    Neither the stock market nor Microsoft give a fat finger about any of us.
    2025-02-11T05:05:17+00:00
    Deep within MS site is an install executable for classic outlook. I would post the link but I forgot to save it (kicking myself). I discovered this by googling the issue and a site unrelated to Microsoft had the link. Perhaps you can find it that way?
    2025-02-11T05:07:01+00:00
    I think a better question is: "When will Microsoft fix all the bugs and return the beloved classic features and functions to 'New' (and useless) Outlook?"
    2025-02-11T05:10:30+00:00
    I wonder what Microsoft does with all its failed product managers? Is releasing a new, totally rewritten version considered training ground for new recruits? Microsoft is clearly getting long in the tooth if this is what they consider appropriate market response.
