Using Classic Outlook on Windows for personal email, calendar, and contact management
I've just discovered that Icloud for Windows is not supported in new outlook. Very disappointing.
Classic Outlook - Until when will it be supported & available for use?
Can users with Classic outlook continue using it in 2025?
The new version will not deliver email to the AT&T .net email system. HELP, HELP
new version makes my proton mail bridge useless.
now i cant communicate with outlook using the proton mail bridge for work related emails
this is a great inconvenience.
The reality is that nobody in Microsoft gives a damn about your proton mail bridge, bud.
But you’ll be able to use the Classic Outlook until 2029 and by then you’ll find a workaround or even find out that Proton went belly up and you won’t need a Proton mail bridge anymore 😬.
Cheers!
Well, it is no longer working for me. I have uninstalled the New Outlook and (that used to give me access to the classic Outlook). Now it tells me that mail and calender are no longer supported. Then it expounds into Windows 11 BS and I don't have Windows 11 and wants me to export my data and login to Google. Any suggestions?
