No spelling suggestions in the right-click menu (New Outlook for Windows)
2024-01-18T13:58:51+00:00
Split from this thread.
I have had the same issue, but I have the Office 365 Outlook app actually loaded on my computer.
It happened when I switched to the new view of Outlook. I am ready to switch back to the old view due to this feature not working. I use it all the time.
It shows the spelling error, but does not provide spelling suggestions in the right click pop up menu.
I checked the editor settings and these are all turned on. I also restarted the application.
    2024-04-15T23:12:09+00:00
    That was a BRILLIANT answer - thank you very much. I had changed back to old outlook as the missing spelling suggestions were SO annoying. I would never in a million years have found that setting without your instructions and would never have thought i needed to turn it on if I had found it. YOU ARE A STAR!! THANK YOU!!!
    2024-04-16T18:47:17+00:00
    That does not work.
  3. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2024-04-16T18:59:54+00:00
    That does not work.
    If you open the e-mail you are composing in a separate window, spellcheck suggestions will work (see previous replies in this thread).
    See also Carlos986's suggestion to enable connected experiences. It is a very useful workaround.
    I recommend that you report the bug to Microsoft using Help > Feedback in the new Outlook.
    2024-04-16T19:31:59+00:00
    After I opened an email in a separate window it worked and now it works all of the time.
    Thanks.
  5. Stefan Blom 353.5K Reputation points MVP Volunteer Moderator
    2024-04-16T19:42:07+00:00
    I'm glad you are seeing progress.
    I want to emphasize that I can't take credit for the connected experiences solution/workaround, though.
