Using New Outlook on Windows for professional communication and productivity
Why you NEVER put print screens on your answers? 90% of the help here refers to features that don't exist in my own outlook-office.
How do I add a note to an email using Outlook
Hi y'all! Sorry I am late to this party, but I just figured it out!
I hope this helps!
P.S. I tried adding a screenshot, but it kept failing.
Thank you for the reply. So when I click on the 3 little buttons, "edit message" isn't an option, only "forward, meeting and translate" (?)
I DO see that you can set a reminder under follow up and adjust that wording to put a little note that will show up at the top when you click on the email, but I was asking if there was a feature like excel where you can HOVER over the email and notes that would show up pertaining to the email (like on a cell in excel) - I believe there isn't but should be developed!
You are clicking the 3 dots in the message section. Above that, and below "File", "Message", etc., you should find a Ribbon that has icons for trash, move, etc. At the end of that Ribbon line, you should see 3 more dots. This will lead to a drop-down list where you select "Actions", then "Edit Message".
This will allow you to make notes (and edits) directly in the email message, but not as you described in excel.
