Using New Outlook on Windows for professional communication and productivity
What version of Outlook do you use?
I use "Outlook (new)" and there the subject section is NOT editable.
How do I add a note to an email using Outlook
If you would like to be able to quickly view in a column the Flag To field text that you entered you can use the following steps. I like to see things at a glance so this columns has helped me better prioritize my custom Search Folders that I have set and hope this will help others.
If you would like to be able to quickly view the due date that you set on the Flag you can use the following steps.
DeAnn,
This is again the solution for old Outlook, the desktop one. I am looking for a solution for the "Outlook New" that is replacing the old one.
Here here, re the "yellow sticky note" feature request. It could be an intuitive feature, right click within the email message and in the menu that shows, one option would be to add a sticky note. I would not care about having the notes accessible elsewhere (like in a notes folder), just so long as the note is stuck to the email message.
