how do I add a note to an email using outlook
2023-09-29T18:35:26+00:00
How do I add a note to an email using Outlook
    2023-10-01T20:06:52+00:00
    Hi KerrieAnn Auclair
    Thank you for reaching out to us.
    I understand that you are having trouble adding a note to an email using Outlook. Let me help you with that.
    First of all, may I know what is the version or product name of Outlook you are using? Is it Microsoft 365 Family/Personal or Business? You may refer to this link here for instructions. About Office: What version of Office am I using? - Microsoft Support
    To add a note to an email in Outlook, you can use the Notes feature. Please note that this feature may not be available in older versions. Here are the steps:
    1. Open the email you want to add a note to.
    2. Click on the "Notes" button in the ribbon at the top of the screen.
    3. A new note window will open. Type your note in the body of the note.
    4. Click "Save & Close" to save the note.
    If you are still having trouble adding a note to an email, please let me know and I will be happy to assist you further.
    Sincerely,
    ReynaldoB
    Microsoft Community Forum Moderator
    2023-10-02T15:15:53+00:00
    Hello, I am using Microsoft Office 365. I thought I was using a new vision of outlook. That note feature is not there.
    2023-10-06T03:48:18+00:00
    Hi KerrieAnn Auclair,
    Thanks for getting back.
    The Notes feature on Outlook is available with Microsoft 365 versions. On your Outlook app, you should be able to use this feature.
    To further isolate the problem, I recommend checking for your Office updates. In that way you can get the latest updates for your Office applications. Install Office updates - Microsoft Support
    Sincerely,
    ReynaldoB
    2023-10-11T01:02:21+00:00
    Hello KerrieAnn Auclair!
    We haven't heard from you in 72 hours, so we assume that your issue has already been resolved. We will not be monitoring this thread moving forward so, if you need further assistance, please create a new thread to discuss these concerns by clicking this link: Create a new question or start a discussion (microsoft.com)
    Thank you for your understanding.
    Sincerely
    ReynaldoB
    2023-10-24T08:05:06+00:00
    In what Outlook versions is this feature "Notes" button in the ribbon available?
    I am using the latest "new Outlook for Windows" Image and Microsoft 365 apps for enterprise and it is not available there... Will it be?
    Piotr
