Tasks in Planner - Assigned to Me. Not Showing in Outlook ToDo
2024-02-22T12:27:15+00:00
I was wondering why my tasks from Planner show up in my ToDo app fine. But in outlook they do not show up.
Please see the My Day in ToDo:
Now in outlook it is like this:
I also Tried the web version:
Would be really useful for this to flow through and I think it should.
    2024-06-11T09:08:40+00:00
    Hello
    I have the some issue, while Planner is on the list of Connected Apps
    it would be great to resolve this because Id like to use the option to drag the tas to the calendar
    2024-06-16T15:20:05+00:00
    I can confirm this issue persists. I'm using the Outlook (PWA) with the sidebar "My Day" opened on tabpage "To Do". I've chosen "Planned" as the list to show.
    There's a task assigned to me in a Planner plan with start- and due date. It does not show in the sidebar. When I just open To Do using the menu on the left in Outlook (PWA) and choose for the list "Planned", it does show that same task that's been assigned to me.
    When creating a task directly in To Do for that same period (start and due date), that does show up in the sidebar panel where it should be. But as tasks are being assigned to me from different planner plans in our tenant it should pick that up in the sidebar no matter what.
    2024-06-20T12:44:15+00:00
    Same problem here. Just adding to get visibility on this problem, hopefully.
    I'm trying to switch to Loop as it meets more of my needs in one place. The tasks assigned to me in Loop will appear in To Do and Planner appropriately but do not appear in the My Day pane at all. I tested tasks Assigned to Me originating in Planner (simply eliminating the extra step between Loop and Planner) and they also do not appear.
    I have Planner toggled on under Connected Apps, as suggested previously in this thread.
    This is a huge functionality issue as it eliminates the ability to create calendar events from tasks and time block the right way.
    2024-06-28T14:10:41+00:00
    I am also experiencing this same issue. The to do plugin in outlook does not show my tasks that were created in planner and are assigned to me. PC user here on the New Outlook app.
    2024-07-17T09:07:08+00:00
    Same issue for me, any tasks assigned to me in Planner are showing in To-Do, but are NOT showing in the Outlook tasks panel on the right hand side of my Outlook calendar. This means I cannot manage my time and work all from one place, I'm forced to navigate back and forth from Planner and Outlook which isn't ideal.
