Using New Outlook on Windows for professional communication and productivity
I agree that MS needs to add that capability in the new outlook! In the meantime I have found a suitable workaround. While I have the calendar open on my screen to the month I want printed, I just hit the prt sc button and then use the snipping tool to select the area I want printed. Then you can print it in a landscape that will fit your needs.
