NEW Outlook will not print in Landscape view
2024-01-26T15:45:57+00:00
The NEW Outlook will NOT print in landscape mode.
I do not get a choice when I click on PRINT. If I go to VIEW, I get to choose from Day, Week, Month etc. Nothing else.
Calendar settings and Print settings (i.e. the cog wheel icon) do not offer any options at all regarding landscape or portrait view.
I have another computer for which I have NOT upgraded to the NEW Outlook and fortunately, it can still print in Landscape mode with it. I also know that shifting to the NEW Outlook will become mandatory later this year.
This is extremely frustrating and so far, nobody has offered anything in the way of a solution.
This is what I get.
What's happening here?
Cam.
    2025-01-17T04:57:39+00:00
    Diddo, my thoughts exactly
    2025-03-24T17:02:07+00:00
    Very frustrating @sandywe@microsoft.com
    2025-03-24T17:27:10+00:00
    I fixed it, after 40 years on Microsoft. I just bought a mini mac. Its increadable, makes windows Pc's look totally pathetic. Everything works as it should instantly.
    2025-05-05T18:02:44+00:00
    i have same issue and increasing frustration with this.
    How to print month view on 1 page. It was easy on classic version of outlook.
    2025-06-17T18:51:57+00:00
    Hey there, I think I found a work around for Macs for this issue. Go to File>Page Setup and change orientation to landscape (and whatever size you want to print), hit OK. Then go File>Print, and the doc should print in those settings. It worked for me; hope it works for others!
