How to fix iPhone calendar not synching with Outlook calendar?
2024-02-15T21:18:33+00:00
If I put event into Outlook calendar on my laptop, it synchs with my iPhone. If I put an event into my calendar on my iPhone, it does not synch with Outlook on my laptop. Works one way but not the other. Help please.
2025-01-21T23:02:21+00:00
Try this:
RESOLUTION via your iPhone:
  • Settings, Apps, Calendar; Default Calendar—Calendar (scroll down to bottom).
  • Calendar app: + (top right to create new Event and verify Outlook Calendar is where Event will be saved); scroll down to Calendar—be sure it points to “Calendar” and not to iCloud [ARLENE] iCloud Calendar—tap Calendar (appointment will now sync and be created on Outlook Calendar).
49 additional answers
    2025-01-21T22:43:26+00:00
    Thanks - this fixes it.
    You will see in "fine print" up the top of the screen "Account not synched" or something like that. There will be a "re-enter password" option - press that and put your password in. Then all the meeting notifications come pouring in.
    My iphone is owned by my work and they use "Duo Mobile" app for security - my best guess is I think after 30 days Duo Mobile drops the outlook synch out and I have to re enter my password.
    2025-02-12T19:20:34+00:00
    Same issue . . . wondering if it has to do with latest iOS18 update on iphone.
    I can put a calendar entry on iPhone, but it doesn't show on Outlook.
    I can make a calendar entry in Outlook on PC and it shows up.
    Strangely, my Outlook calendar on my iPhone though shows all the appointments.
    Now I just need that to happen on iPhone calendar and on PC calendar.
    Super frustrating this keeps happening.
    Last time I had to retype everything into PC to get on iPhone calendar.
    This happened to me 3 months ago as well. What is the solve?
    2025-02-28T18:17:16+00:00
    I have the same question in reverse. Events added in my iPhone calender show up in Outlook on my desktop, but not the other way. Events added in Outlook don't show up on iPhone calender.
    2025-03-04T05:26:03+00:00
    this has not worked for me. please help
