How to fix iPhone calendar not synching with Outlook calendar?
2024-02-15T21:18:33+00:00
If I put event into Outlook calendar on my laptop, it synchs with my iPhone. If I put an event into my calendar on my iPhone, it does not synch with Outlook on my laptop. Works one way but not the other. Help please.
2025-01-21T23:02:21+00:00
Try this:
RESOLUTION via your iPhone:
  • Settings, Apps, Calendar; Default Calendar—Calendar (scroll down to bottom).
  • Calendar app: + (top right to create new Event and verify Outlook Calendar is where Event will be saved); scroll down to Calendar—be sure it points to “Calendar” and not to iCloud [ARLENE] iCloud Calendar—tap Calendar (appointment will now sync and be created on Outlook Calendar).
49 additional answers
    2024-08-27T17:32:31+00:00
    Thanks. I've checked but the default is still set to my same gmail calendar as before... no change.
    2024-08-29T15:35:12+00:00
    All:
    Here is what I did to fix the problem:
    Step one: go to iCloud Calendar (https://www.icloud.com/calendar)
    Step Two: Sign in with apple ID credentials.  If you have a newer iphone once you put the email in, there is aQR code you scan and it signs you in.
    Step 3: on the left hand side, find the calendar you want to sync.
    Step 4: Hover over it and select the little person icon and select public calendar.
    Step 5: copy the link
    Step 6: go to Microsoft outlook calendars
    Step 7: Add calendar
    Step 8: Click the "Subscribe from web" option and paste in the link.
    Step 9: Click import
    It should sync from there. Or at least it worked for me!
    2024-09-20T13:24:43+00:00
    I figured out the solution for me, might work for you too. Go to your iPhone settings>Mail>Accounts then select the account with the issue. I had to re enter my password, and then it will sync. Hope this helps ☺️
    2024-09-27T09:39:59+00:00
    Thanks for sharing your solution. I tried this but in my case it only syncs one way i.e. from iPhone to Outlook but it doesn't sync from outlook tot iPhone.
    I haven't found the solution yet.
    Regards,
    Peter
