How to fix iPhone calendar not synching with Outlook calendar?
2024-02-15T21:18:33+00:00
If I put event into Outlook calendar on my laptop, it synchs with my iPhone. If I put an event into my calendar on my iPhone, it does not synch with Outlook on my laptop. Works one way but not the other. Help please.
2025-01-21T23:02:21+00:00
Try this:
RESOLUTION via your iPhone:
  • Settings, Apps, Calendar; Default Calendar—Calendar (scroll down to bottom).
  • Calendar app: + (top right to create new Event and verify Outlook Calendar is where Event will be saved); scroll down to Calendar—be sure it points to “Calendar” and not to iCloud [ARLENE] iCloud Calendar—tap Calendar (appointment will now sync and be created on Outlook Calendar).
49 additional answers
    2025-06-06T16:24:30+00:00
    Glad it helped you!
