How to fix iPhone calendar not synching with Outlook calendar?
2024-02-15T21:18:33+00:00
If I put event into Outlook calendar on my laptop, it synchs with my iPhone. If I put an event into my calendar on my iPhone, it does not synch with Outlook on my laptop. Works one way but not the other. Help please.
2025-01-21T23:02:21+00:00
Try this:
RESOLUTION via your iPhone:
  • Settings, Apps, Calendar; Default Calendar—Calendar (scroll down to bottom).
  • Calendar app: + (top right to create new Event and verify Outlook Calendar is where Event will be saved); scroll down to Calendar—be sure it points to “Calendar” and not to iCloud [ARLENE] iCloud Calendar—tap Calendar (appointment will now sync and be created on Outlook Calendar).
49 additional answers
    2025-06-03T18:25:04+00:00
    I have spent months trying to sort this out. THANK YOU so much.
    The expert in the APPLE store told me it could not be done
    An IT expert told me it could not be done.
    All I had to do was change the DEFAULT CALENDAR
    It works now.
    WONDERFUL
    2025-06-03T22:22:01+00:00
    Glad it worked out. These forums are invaluable.
    2025-06-06T15:50:48+00:00
    This worked for me. Thank you!!!
    2025-06-06T15:54:53+00:00
    I think I may be duplicating my reply - but reentering my password for the outlook account in the iphone mail app also worked for me. Thank you so much -- to whoever posted : )
