How to fix iPhone calendar not synching with Outlook calendar?
2024-02-15T21:18:33+00:00
If I put event into Outlook calendar on my laptop, it synchs with my iPhone. If I put an event into my calendar on my iPhone, it does not synch with Outlook on my laptop. Works one way but not the other. Help please.
2025-01-21T23:02:21+00:00
Try this:
RESOLUTION via your iPhone:
  • Settings, Apps, Calendar; Default Calendar—Calendar (scroll down to bottom).
  • Calendar app: + (top right to create new Event and verify Outlook Calendar is where Event will be saved); scroll down to Calendar—be sure it points to “Calendar” and not to iCloud [ARLENE] iCloud Calendar—tap Calendar (appointment will now sync and be created on Outlook Calendar).
49 additional answers
    2025-03-28T21:43:22+00:00
    My outlook calendar doesn't synch to my iPhone. I tried speaking to your tech support as well as to apple's and no-one seems to be able to solve this issue.
    2025-03-28T21:57:19+00:00
    This problem, in my case, is related to the SnapDragon ARM64 processor. Apple needs to compile a 64 bit version of Icloud for Windows on a Snapdragon processor. Apple seems reluctant to provide Microsoft with a solution that will fix a problem on the Snapdragon Laptops which compete with Apple MacBook processors.
    So until the magic FIX day comes I have my Icloud Calendar open in a Windows Browser as my home page...works for me as most of my calendar action is on my iPhone.
    2025-04-15T17:16:10+00:00
    I need help getting my contacts and calendar events on iphone to link or sync to Microsoft Outlook. Is there an agent to help me?
    2025-05-12T10:33:16+00:00
    We had the same issue. Turned out that Outlook (Outlook app needed to be installed also) notifications needed to be turned on. No other settings worked! (well after a few minutes)
