How to fix iPhone calendar not synching with Outlook calendar?
2024-02-15T21:18:33+00:00
If I put event into Outlook calendar on my laptop, it synchs with my iPhone. If I put an event into my calendar on my iPhone, it does not synch with Outlook on my laptop. Works one way but not the other. Help please.
2025-01-21T23:02:21+00:00
Try this:
RESOLUTION via your iPhone:
  • Settings, Apps, Calendar; Default Calendar—Calendar (scroll down to bottom).
  • Calendar app: + (top right to create new Event and verify Outlook Calendar is where Event will be saved); scroll down to Calendar—be sure it points to “Calendar” and not to iCloud [ARLENE] iCloud Calendar—tap Calendar (appointment will now sync and be created on Outlook Calendar).
49 additional answers
    2024-02-16T02:57:00+00:00
    Good day!
    Thank you for posting to Microsoft Community. We are glad to assist.
    We are looking into your situation, and we will update the thread accordingly.
    Appreciate your patience and understanding and thank you for your time and cooperation.
    Sincerely,
    Microsoft Community Moderator.
    2024-02-16T05:26:54+00:00
    Hi, Claudia Monte
    Good day.
    Thank you for posting to the Microsoft Community. We are glad to assist you.
    According to your description, to fix the issue of iPhone calendar not syncing with Outlook calendar, please follow these steps:
    1. Check if your iPhone is connected to the internet and if the Outlook app is up to date.
    2. Make sure that you have enabled the option to sync your calendar in the Outlook app on your iPhone. To do this, go to Settings > Passwords & Accounts > Outlook > toggle on the switch for Calendars.
    3. Check if the events you added on your iPhone are saved to the correct calendar. Sometimes, events may be saved to a different calendar, which may cause syncing issues.
    4. If the above steps do not work, try removing and re-adding your Outlook account on your iPhone. To do this, go to Settings > Passwords & Accounts > Outlook > Delete Account. Then, add your account again by going to Settings > Passwords & Accounts > Add Account > Outlook.
    If the issue persists, would you please be kindly to refer Outlook for iOS dedicating team as below:
    Outlook for iOS
    Tap your profile photo and then the ? > Contact Support.
    Image of the message list in Outlook for iOS.
    Image of the left nav pane in Outlook for iOS.
    Choose Contact Support
    Thanks in advance for your understanding! Your patience and cooperation will be highly appreciated. Hope you all the best!
    Best regards,
    2024-03-05T17:54:25+00:00
    Thanks for your guidance. However, I have not been using the Outlook App. My mail/calendar accounts are in Mailboxes that were installed with my iPhone. Never had a problem before. This lack of calendar synching is a new one. Do you have any more advice for me? Thanks.
  4. Deleted
