Using New Outlook on Windows for professional communication and productivity
Hi All!
I stumbled upon the solution by pure happenstance ... it's so dumb!
If you open any email in a separate pane (by double-clicking it), you'll notice that pane has an independent zoom button at the top of the new window:
This zoom button will also change the zoom of your email in the normal reading pane. Somehow mine was set to like 60%, which is why all the text was super tiny. What a dumb setting! No way to change it anywhere else, as far as I can tell 🤦♀️
Hopefully this helps someone!
Thank you!!!!
The solution we've all been looking for!! WooHoo!!
