Using older versions of Outlook for Mac in business environments
I am having the same problem.
Hi there,
my Outlook for Mac does not download or open any attachments.
The issue persists with various file types such as jpeg, xls, pdf.
The workaround with downloading the files and opening them from the finder does not work, as I am unable to save the attachments. I do see the attachments by name and icon (e.g. Apple Preview PDF icon)
macOS and Outlook are up-to-date:
macOS Version: 12.5
Outlook Version:16.64
The issue appeared on my newly installed Macbook Air M2 with macOS Monterey. On the old Macbook Pro before I did not encounter this issue.
As is, I just cannot work with an Email client not opening attachments. Thanks in advance for any solution.
Best regards,
ste_si
*** Update: Seems to be caused by the "new Outlook". Going back to the legacy Version solves the issue, everything works fine. Anyone else experiencing this issue? ***
Same here too. reverting to legacy works, but that's pretty rubbish MS!
Hi, I all have same issue here
Please let me know if the problem have been solved
same issue with me ....
