how to delete more than 10 contacts in outlook 365, how to delete more than 50 contacts in outlook 365
2023-02-03T18:24:46+00:00
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
Outlook | Web | Outlook.com | Contacts
    2023-09-04T20:52:27+00:00
    Hi everybody!
    After unsuccessful attempts to delete 1000+ contacts from my Hotmail account I created Python script that removes all contacts from your hotmail.com/outlook.com account
    I used Basic authentication (still supported by Hotmail) but you can change it to OAUTH2 if your server requires it.
    See https://github.com/Symnok/DeleteHotmailOutlookContacts/tree/main
    Feel free to modify this program to your needs (at least you need to use your own credentials)
    This python3 program removes all contacts at ones.
    1. Install python3
    2. Install exchangelib: pip install exchangelib
    3. This program uses Basic Authentication (not OAUTH2) that still (as of Sept 1 2023) supported by Microsoft for outlook.com/hotmail.com The code uses MS Exchange server m.hotmail.com but you can modify the code to use any of the following URLs as of September 1 2023:
    m.outlook.com
    outlook.office365.com
    eas.outlook.com
    s.outlook.com
    In the code, set your hotmail.com/outlook.com credentials in
    ACCOUNT_USERNAME_AND_EMAIL
    and
    ACCOUNT_PASSWORD
    1. 2FA supported! If you use 2FA, generate application password and set its value to ACCOUNT_PASSWORD
    2. You must use modern OS that supports TLS 1.2. TLS 1.1 and below is not supported anymore by the corresponding Exchange servers
    1. Use this program on your own risk. It may contain bugs that can cause data loss, email loss, contacts loss, Microsoft/hotmail.com/outlook.com and any other account suspension, account deletion, permanent ban by Microsoft and other unexpected consequences. USE THIS PROGRAM ON YOUR OWN RISK!!!
    1. This program may not work if your account registered using non-Microsoft email address. Add Microsoft email address *@outlook.com) to your account, make it Default Alias and use this email with this program.
    2. Run this program as python3 deleteHotmailOutlookContacts.py
    3. On UI https://outlook.live.com/people/0/?actSwt=true turn ON New Contacts option. The program will work without this option too but you will not see if some contacts are stuck and not deleted
    4. You may need to run this program few times before al contacts are deleted. Wait 3-5 mins before second and additional runs. You may need to remove a few remaining contacts manually.
    2023-09-18T10:40:31+00:00
    Hi MarekSzczerba,
    I understand how you feel and the frustrations when you accidentally synced your iPhone Contacts to your personal Outlook.com contacts. According to this situation, the only way to clear up your personal Outlook.com contacts is By Select 10 contacts at one time and delete them, and repeat this process until you finally clear up all the contacts.
    Given the expectations as below:
    • I want to delete all my entire Outlook.com contacts
    • I wish my every 1 second can delete 1 contact in my Outlook.com contacts
    • I do not want spend my entire time / lifes / days to manually delete the contacts 10 by 10
    Here is the solution ideas:
    1. Go to make.powerautomate.com
    2. Sign in with your Outlook.com email
    3. Click "+ Create"
    4. Click "Schedule cloud flow"
    5. Follow the settings as below screenshots: - Please ensure a one minute gap before the actual starting time. Flow name can be any :)
    6. Click "Create"
    7. Under Recurrence, click "Show Advanced Options"
    8. Select your timezone
    9. Click "+ Add new step"
    10. Search & Select "Outlook.com"
    11. Search & Select "Get Contacts"
    12. Under Get Contacts action, click "Show Advanced Options"
    13. Put "10" as your Top Count
    14. Click "+ Add new step"
    15. Search & Select "Outlook.com"
    16. Search & Select "Delete Contact"
    17. Select "Contacts" as your Folder Id
    18. Under "**Id" ,**click any blank area and open Dynamic content menu, Search & Select "Id"
    19. Once you done, click "Save"
    20. You can test your flow if is working with "Test > Manually"
    21. When your flow ran successfully, continue your work or give yourself a rest. Let the Power Automate take over the rest.
    Expected Outcome as below:
    1. I have 4000 contacts to be deleted
    2. 1 second can delete 1 contact
    3. Total time required = 4000 seconds
    4. 4000 seconds = 1.1 days
    In summary, once you set up this flow, the next day you will see all your Outlook contacts has clear up.
    Note: Once you checked all your contacts had deleted, kindly please Turn Off the flow.
    Lastly, above solution is applicable for Outlook 365.
    Hope it helps ;)
    2023-09-18T13:40:37+00:00
    I have more simple solution. I created Python program that deleted all outlook.com contacts:
    https://github.com/Symnok/DeleteHotmailOutlookContactsIt works with all email addresses in @hotmail.com and @outlook.com . It may not work with corporate Exchange / Office365 email because of different authentication methods.
    2023-09-20T06:57:12+00:00
    Same issue from my end. MS please allow option to bulk delete entire contacts. This is hectic to delete 10 by 10.
    2023-09-20T14:08:04+00:00
    Hi Dhivya Sengottaiyan,
    You can try out my following solution.
    3. Click "+ Create"
    5. Follow the settings as below screenshots: - Please ensure a one-minute gap before the actual starting time. Flow name can be any :) ![Image](https://learn-attachment.microsoft.com/api/attachments/e5a6e26e-d8a8-4465-8706-a3ac985d353a?platform=QnA
    6. Click "Create"
    Once you set up this flow and let it run, the next day you will see all your Outlook contacts has cleared.
    Once it done, please Turn Off the flow.
