how to delete more than 10 contacts in outlook 365, how to delete more than 50 contacts in outlook 365
2023-02-03T18:24:46+00:00
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
Outlook | Web | Outlook.com | Contacts
    2023-03-13T23:48:48+00:00
    I'm having the same issue. I need to delete over 1200 contact and when I select all, the delete option disappears with a message saying "you have selected more than 10 contacts". Nothing else is offered.
    I need to delete all my contacts at once.
    2023-03-17T20:10:55+00:00
    I had the same problem. I'm on a mac book pro revert your outlook back to Legacy. Select the help section of your browser. Once that is done go to contacts and hold shift+A then delete. Then revert back to the new version. It worked for me! I tried to add a screenshot but it will not upload.
    2023-04-01T03:16:34+00:00
    There is no Delete option and all it tells me is you have selected 300 contacts.
    2023-04-10T23:40:15+00:00
    I have the same issue. My contact list grew when using link to windows and I went from a small list of contacts about 50 to now 22,000.
    Deleting 10 at a time is going to take days if not weeks because Microsofts bad programming with link to windows. All the new contacts that are duplicated have (contacts synced by Link to Windows) and destroyed my phone and contact lists.
    Not happy with only being able to delete 10 at a time
    2023-04-11T06:26:51+00:00
    I have the same problem.
    Please implement as fast as possible in the new version of outlook.com (private) the option to delete MORE then 10 contacts.
    Crazy that the developers limited this to 10.
