how to delete more than 10 contacts in outlook 365, how to delete more than 50 contacts in outlook 365
2023-02-03T18:24:46+00:00
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
Outlook | Web | Outlook.com | Contacts
    2024-11-21T19:30:13+00:00
    OMG - he just told you how to delete ALL of your Contacts not duplicates!!!
    2024-11-29T14:00:50+00:00
    Is this a joke ? I tried to delete 3400 contacts with a lot of patient, 50 contacts per delete, then 10 contacts per delete.
    This started because there is a problem with double and triple entry contacts.
    Next day i logged in and the contacts where still there. Please fix this, it is extremelly dificult to use and very annoying.
    2024-11-29T17:47:51+00:00
    Really annoying. Microsoft need to create a de duplication system. I’m switching to Zoho or at least gmail allows the removal and merging of duplicates. Outlook is way behind.
    2024-11-30T12:16:35+00:00
    Hi Yuhao Li,
    Sorry, but this doesn't work. When selecting all there is no possibility to delete .... Only with less numbers (like 10)
    Jeroen
    2024-12-10T19:53:26+00:00
    Yes, I agree that this is absolutely insane and ridiclulous to have to only delete 10 at time...why is there a limitation on this...so, idiotic. What's even sadder is that you can see the date of the original post and it's been over a year since it it posted and all these people are disgusted. You would think the powers that be at Microsft would get up off their **** and fix it!!
