Organizing and accessing contact information in Outlook.com
i can select all the contacts but am unable to delete them. Why is this? Is there a way around it?
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
This is easy to accomplish, though not exactly simple. From Outlook export ALL contacts to an Excel file. Open the file in Excel. Edit the file. Save the file. In Outlook delete ALL contacts. Then import the edited file from Excel.
SOLVED!!
Switch to classic view or app. Either by toggle switch in the top right corner, or by going to Help > Go to Classic Outlook.
Then open contacts tab on the left (Two people logo):
Done!
Didn't work. Once I launched the New Outlook after completing all your steps on the Classic Outlook, all my previous duplicates were still there -- nearly 10,000 of them!
Sorry to hear that. Worked for me with 2,700. Perhaps a volume issue?
Perhaps try again with a smaller test batch to check procedure?
