how to delete more than 10 contacts in outlook 365, how to delete more than 50 contacts in outlook 365
2023-02-03T18:24:46+00:00
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
Outlook | Web | Outlook.com | Contacts
    2024-09-27T11:26:01+00:00
    I had this problem with the New Outlook with MS Office 2021 (Cannot delete more than 10 after bad import) but by reverting to Classic Office I could delete all the contacts and start again.
    I created a new contacts folder in Classic Outlook and imported the contacts that I needed then I reverted to New Outlook.
    Personally the jury is out on which I prefer..
    2024-09-28T20:11:37+00:00
    Thanks so much. I'll give it a try and see what happens. Do you think I should delete Office 365 and Outlook and start over with an install of the Classic Office app? I'm going to search Microsoft for that app. If you have a direct link please post it. thanks again.
    2024-10-17T18:10:40+00:00
    I have 50000 deleted contacts in my deleted contact folder but it won't let me empty the deleted contacts folder in mass, it limits me to 50 contacts at a time. any ideas?
    2024-10-17T19:30:21+00:00
    This doesn't work for me. When I Select All in Contacts, the Delete button is greyed out. I also get the message that I have selected more than 10 contacts. I have 612 contacts. I'm having to go through selecting 10 at a time and deleting them like that, and sometimes I get a message saying that something didn't work and I have to try it again.
    2024-10-17T19:49:29+00:00
    can only delete 10 at a time. this sucks!
