how to delete more than 10 contacts in outlook 365, how to delete more than 50 contacts in outlook 365
2023-02-03T18:24:46+00:00
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
Outlook | Web | Outlook.com | Contacts
    2024-03-15T21:01:27+00:00
    what would microsoft have to lose here other than customers? am i missing why they dont address this? are they worried about idiots who accidentally delete contacts? then just add a confirm step...
    2024-03-15T21:10:22+00:00
    The closest to a solution. but i am also stuck with a 50 limit. Bummer. But good experimenting. The delete is still greyed out once i select more than 50. You can use your <SHIFT> key with your cursor on a range on apple to select a group to delete.
    2024-04-05T09:49:33+00:00
    THANK YOU SO MUTCH !!!
    2024-04-15T05:52:12+00:00
    ___________
    MVP OShon
    I tried this technique:
    1. Open your contact list in Microsoft 365 Outlook.
    2. Click on the first contact at the top of the list to select it.
    3. Scroll down to the last contact you want to include in your deletion.
    4. Press and hold the Shift key on your keyboard, then click the last contact. This action selects all contacts between the first and last one you clicked.
    5. Now, with the contacts selected, you can delete them. Note that attempting to select all contacts at once without using this method may not permit deletion.
    6. This technique allows for the deletion of multiple contacts—up to 35 at a time in my experience—more efficiently than selecting each contact individually for deletion.
    2024-04-25T13:55:34+00:00
    I have just wasted a lot of time checking all my obsolete or duplicate email contacts. Now I cannot delete them! Ridiculous. My solution: Forget about Outlook Mail and go back to Thunderbird and/or Gmail.
