Organizing and accessing contact information in Outlook.com
Thanks Abjay.. helped a little.. instead of limit of 10, its now 50.. but still better than 10 at least.
This is conceivable. I've been using Apple and iCloud for the last 15 years. For some time I wanted to check how to work on WIN 11. For mail and contacts, I chose Outlook in 365.
Something bad happened in the contact database and I had to delete them all to upload new ones. I had almost 3000 of them and now attention:
To do this, you need to delete them with 10 pcs. !
Then, to delete them from the deleted folder, you need to delete with 50 pcs.
It is unlikely that it lacks such basic features that have been present for a long time in google and iCloud.
Can anyone answer the question why this is so?
___________
Piszesz po angielsku - przenoszę na portal angielski.
MVP OShon
***Moved from Outlook/Outlook for Windows/for home***
Strange, I was able to delete 67 contacts at once.
Glad it helped you, a little :D
BRILLIANT. This worked for me. Over 6000 deleted at once from three contacts books. Had to refresh a few times.
MANY MANY MANY thanks!
hola.
A mi no me sale lo que tienes señalado en rojo
This process worked perfectly. Thank you!
