Using Classic Outlook on Windows for personal email, calendar, and contact management
Starting in safe mode and closing out and reopening worked! Thanks.
The Outlook Navigation Pane moved from bottom to left. How can i move it back to the bottom of the pane?
That just worked! Amazing!!
Seems this trick is no longer working.
Does anyone else have a way to move the shortcut buttons back to where they were?
Please stop fixing things that are not broken or stealing more screen real estate only to waste space.
found a post from logiccloudit.com with the registry entry which will restore the shortcut icons back to the bottom of the left nav pane.
Thank you, LogicCloudIT!
Thank you so much, mine is now fixed. :)
