Using Classic Outlook on Windows for personal email, calendar, and contact management
Starting in safe mode and closing out and reopening worked! Thanks.
The Outlook Navigation Pane moved from bottom to left. How can i move it back to the bottom of the pane?
I agree. I only do them when I have to. My menu structure is different. I don't have that sub menu.
How did you determine it was that menu? I am interested in that process for future issues.
I found that setting from a suggestion on another site (see previous post). I'm not certain what determines who sees it or who doesn't. I've seen a couple of other forum posts where others are saying they don't see it either. I took another screenshot, this one is of the message that appears when I hover over the 'info' icon ...
My other users have this as well, so it may be something related to our MS 365 tenant, but I wouldn't what that is.
Given that it says "snooze", it's eventually going to be taken away. You're probably further along with the update process, so you're not seeing it and can't change back. My "snooze" change will be taken away, probably after this weekend's Patch Tuesday updates. Just a guess.
It worked! Thank you! You have made my day / week / month/ maybe year!
