A high-level, general-purpose programming language, created as an extension of the C programming language, that has object-oriented, generic, and functional features in addition to facilities for low-level memory manipulation.
C# to C++/MFC duplex mode - Concept
I have a static MFC C++ application, I cannot change it. (CLI is not possible)
I now need to pass data from a C# DLL in the C++ application and transfer it from the C++ to the C# DLL. What possibilities do I have to implement this successfully.
Can you show an example
SendDataOrderToCPP(string order, double price, int amount)
ResponseDataOrderToCSharp(string order, double price, int amount)
Is there a possibility that the C# DLL sends an event and I can evaluate the value in the C++ app?
Is it possible that the C++ exe sends an event and I can evaluate the value in the C# DLL?
How would I have to create this?
Background
I need to implement a WinForm in C# in which I can make inputs. I have to analyse these inputs in C++.
After the analysis, I have to send new data from C++ to C# to display the calculated values.
Or I need an additional DLL ?
Developer technologies | C++
Developer technologies | .NET | .NET CLI
A cross-platform toolchain for developing, building, running, and publishing .NET applications.
Developer technologies | C#
An object-oriented and type-safe programming language that has its roots in the C family of languages and includes support for component-oriented programming.
Deleted
