Outlook desktop client emails missing text in body
2021-05-11T19:46:55+00:00
I have Outlook downloaded from my Office 365 subscription and am running Outlook on a Windows 10 PC.
Today, around five hours after I started working, the text in the body of the email stopped showing, either all missing or just showing the first line.
When I look in the reading pane, all I see is "Hi Bee," and then nothing else. I have checked the emails on my iPhone 7 Outlook and Mail apps, and the body of the message is showing correctly.
I have disabled all COM Add-ins and I have run the full repair on the application, closed down the PC and restarted after a one minute break but still, it doesn't show correctly.
Any help gratefully received!
    2021-05-11T20:22:05+00:00
    Same issue with all click to run 2016 and 2019 here. please fix, I have the after hours phone this week...I don't want to have to tell hundreds of people this is a MS issue all night...
    2021-05-11T20:23:42+00:00
    Same here. After the problem occured I updated to 16.0.13929.20206. No improvement. Trying to roll back tomorrow, if nothing changes.
    2021-05-11T20:24:08+00:00
    Thanks you!  This worked!   Stupid Microsoft.
    2021-05-11T20:26:38+00:00
    Same problem. Happened sometime since yesterday afternoon. Looks to be a MS problem with a recent update. I will wait a day to see if they fix it before trying to roll back to the previous version. In the meantime I will use Outlook on the Web. That is working OK.
    2021-05-11T20:27:53+00:00
    The rollback takes just a couple minutes...
    "C:\Program Files\Common Files\microsoft shared\ClickToRun\officec2rclient.exe" /update user updatetoversion=16.0.13901.20462
