Using Classic Outlook on Windows for personal email, calendar, and contact management
THIS WORKED!! Thank you so much!!
All Office application display the menus, ribbons, sidebars as way too large.
It is not an issue where going to Settings->Display->Scale & Layout, setting to 100% will fix it. I already have that set. I have also toggled the 'When using multiple displays options' several times within Office applications settings.
Everything else is just great with my display. All text within the viewing panes of Office applications is fine. For instance, in Outlook, the ribbon is huge, the sidebar is huge, I can only see about 4 emails at a time listed. However, where it displays a full email on the right, that text is just fine. If I lower the zoom level it gets too small to read. Also that zoom level does not affect the size of the ribbon or side bar. Same issue in Excel. Ribbon is huge, but the cells of the spreadsheet are normal size.
The file explorer menus and ribbon also display fine. All other non-office applications display fine.
It was working fine. I must have pressed some button inadvertently which increased the size of these items. Or maybe it was because I temporarily hooked my laptop up to a different monitor.
This worked! I don't know how you figured it out but Thank you for doing so!! I've spent days trying to figure out how to fix this issue. It happened after I did the last update and I could not understand what happened or how I should fix it.
Thanks Again!!
Thank you!!!
This worked! thank you so much! you're a lifesaver!
Ok I finally found a solution that worked for me.
The problem arouse after an update and involved all the offices app.
Makes no sense but have a try:
- Desktop --> Display settings
- Search for "Make text size bigger" and click
You probably have the "Make text bigger" already at minimum value, nonetheless enhance it (105% or something like that)
- Apply
- Now it should be back working, is it? Now you can come back at 100% and it's going to be displayed properly.
**Edit: Try to restart one of the application affected, if opened
Hope it helps
I am so glad I found this response. Your reccomendation worked like a charm. This has been driving me bonkers for weeks since getting my new work computer.
