Office Ribbon Too Big -- not a display resolution issue
2021-08-06T18:16:52+00:00
All Office application display the menus, ribbons, sidebars as way too large.
It is not an issue where going to Settings->Display->Scale & Layout, setting to 100% will fix it. I already have that set. I have also toggled the 'When using multiple displays options' several times within Office applications settings.
Everything else is just great with my display. All text within the viewing panes of Office applications is fine. For instance, in Outlook, the ribbon is huge, the sidebar is huge, I can only see about 4 emails at a time listed. However, where it displays a full email on the right, that text is just fine. If I lower the zoom level it gets too small to read. Also that zoom level does not affect the size of the ribbon or side bar. Same issue in Excel. Ribbon is huge, but the cells of the spreadsheet are normal size.
The file explorer menus and ribbon also display fine. All other non-office applications display fine.
It was working fine. I must have pressed some button inadvertently which increased the size of these items. Or maybe it was because I temporarily hooked my laptop up to a different monitor.
    2023-11-22T17:41:17+00:00
    Try this it worked quick and it was easy. Just click display settings on the bottom of the screen and hit optimize for compatibility.
    Boom its fixed. Worked like a charm for me.
    2023-12-03T23:39:52+00:00
    This worked for me and fixed the problem.
    2023-12-04T14:05:30+00:00
    I had the same issue. Here is the fix that worked for me:
    On the desktop, right click to open Display Settings
    In the menu on the left side, click Accessibility
    Open Text Size
    Adjust the text size slider to any number besides 100% and click Apply
    Change the slider back to 100% and click Apply again
    2023-12-05T13:53:55+00:00
    Thank you!!!! This worked!!
    2023-12-06T01:33:07+00:00
    Hi, just want to acknowledge your feedback. Works great!! Thanks
