Office Ribbon Too Big -- not a display resolution issue
2021-08-06T18:16:52+00:00
All Office application display the menus, ribbons, sidebars as way too large.
It is not an issue where going to Settings->Display->Scale & Layout, setting to 100% will fix it. I already have that set. I have also toggled the 'When using multiple displays options' several times within Office applications settings.
Everything else is just great with my display. All text within the viewing panes of Office applications is fine. For instance, in Outlook, the ribbon is huge, the sidebar is huge, I can only see about 4 emails at a time listed. However, where it displays a full email on the right, that text is just fine. If I lower the zoom level it gets too small to read. Also that zoom level does not affect the size of the ribbon or side bar. Same issue in Excel. Ribbon is huge, but the cells of the spreadsheet are normal size.
The file explorer menus and ribbon also display fine. All other non-office applications display fine.
It was working fine. I must have pressed some button inadvertently which increased the size of these items. Or maybe it was because I temporarily hooked my laptop up to a different monitor.
    2023-09-07T18:33:33+00:00
    This fix is amazing, BUT is there a way to modify the code you provided and make everything slightly bigger? The size is much better than it was, but it's just a little too small now for my old eyes.
    2023-09-12T20:12:14+00:00
    i'm using chrome and i found that using the browser zoom in and out at the bottom right of the page wasn't working, but the magnifying glass all the way to the right in the address bar worked
    2023-09-18T02:34:41+00:00
    Thank you, this worked for me!
    2023-09-20T20:45:02+00:00
    This solved the issue for me
    2023-09-27T14:46:31+00:00
    I accidentally made the ribbon large and came here looking for a fix but none of these worked. So I thought back to what I was doing when I accidentally made the ribbon larger and was able to fix so:
    1. click on the ribbon on Microsoft 365
    2. hold down ctrl and press the - key to reduce
    3. if you go too far press ctrl and + to increase.
