Error code 80090016 Trusted Platform Module has malfunctioned.
2020-03-03T17:45:17+00:00
When I try to add a new Office 365 email to my outlook I get the error below.   I think it's because of my "Work or school account" which I want to remove. I'm not sure how my email was signed up for this second account. I set up this computer for home use only, I won't be using any of the Microsoft Azure features.
My question is, what will happen when I remove my “work account” and leave my Microsoft account?  Everything is backed up on Onedrive, I just don’t know what to expect because when I went to remove it, it warned me about losing data and settings.
Any help would be appreciated. Thank you!
    2021-04-21T16:47:23+00:00
    Here's an easier solution. We've tried this on 4 different machines so far, and it has worked successfully on all of them.
    • Launch tpm.msc as an admin.
    • Right-click on TPM Management in left frame.
    • Select Clear TPM.
    • Reboot the computer and have the user log in and try again.
    2021-04-26T15:53:15+00:00
    Do you have Bitlocker enabled on these computers?  I'm wondering if that causes a Bitlocker prompt.
    2021-04-26T18:31:55+00:00
    We do have BitLocker enabled on these computers and did not receive any type of prompt.
    2021-04-26T18:52:57+00:00
    I have Bitwrden which is just like Bitlocker
    2021-05-04T13:40:19+00:00
    I have a system which uses TPM + Bitlocker, with AMD Ryzen - with this as the TPM. I recently updated the BIOS, and after that, re-enabled TPM in the BIOS, and from then onwards, was prompted for my bitlocker recovery key on every boot after that.
    To fix this, I cleared the TPM by:
    • Select Clear TPM.
    • Shutdown + Power on the machine (Restart didn't trigger Bitlocker)
    • Enter the Bitlocker recovery when prompted.
    After this, Bitlocker didn't bother me anymore, but Outlook did, with the errors mentioned in this post.
    I fixed this by:
    • Run powershell as administrator (with the affected user)
    • Running 'dsregcmd /status' will likely show "deviceauthstatus : failed. error:8007013d"
    • Run 'dsregcmd /debug /leave', reboot, and then open Outlook, you'll get a login prompt, and things should be good from there.
    Hopefully this helps someone.
