Outlook for Android opening links in internal browser
2020-07-05T11:24:17+00:00
Hi, I noticed that all my links in my Android Outlook app open in an in build browser instead of the app, (such as youtube) This is really frustrating as I have to do other steps to find the option to 'Open in browser' so it then opens in the youtube app. This is for all links amazon, twitter etc.
Is there any way to disable this option? I am unable to find it in settings withtin the app.
Moved from: Options and settings / Email settings
Outlook | Outlook for mobile | Outlook for Android | For business
    2021-03-11T09:08:30+00:00
    Why did no one else point this out?!?
    2021-03-11T12:42:47+00:00
    This was first pointed out in this thread at the start of November, when this choice was added to the Android client.
    2021-03-11T13:13:23+00:00
    Sorry forgot to add the sarcasm tags
    2021-03-16T07:14:38+00:00
    Click the Home icon in the top left corner >
    Click the settings cog in the bottom left corner >
    Scroll down to "Preferences" >
    Toggle "Use default browser".
    Hope this helps.
    Edit:
    I see this was already answered by ButterCup86 & DanTr_9, my apologies. @microsoft get it pinned!
    2021-03-29T22:58:21+00:00
    Hi
    I was frustrated by Outlook opening weblinks inside the Outlook app.
    If you tap the gear symbol (settings) in Outlook then go to preferences and select "Use default browser" weblinks will open directly in your default browser.
